Hi,
I have Xperia Z , All of Sudden my Phone Stopped Respoding and Need to Reboot the Phone and after rebooted still the same. I have tried inserting another SIM , But this time the Phone reboot automatically after i insert SIM. and my Device Locks ny Mcafee. Device works fine Without the SIM Card. I dont have the SONY service center here.
Error: red "X" on the SIM and same for the signal.
Checked there is no issues with the SIM.
I was using the Phone for past one month with no issues. Does factory reset would resolve the problem?
Any help on this Regards
@Mahsa95 wrote:hi. i have the same problem . the phone ( z.c6602) was working fine . suddenly i have no more signal . x mark on signal bars . and i cant connect to pc anymore. pc doesnt detect the phone . sony companion too . i cant update the android to 5. stops on 60% 70% . plz spmebody help ! i cant reset to factory day because i dont remember my clash of clans gmail and password . very terrible position :'(
Termed highly recommend phone zr isn't detecting any sun please help
I had the same problem and solved it by going to Settings / under Wireless & Networks select MORE...../ select MOBILE NETWORKS / select NETWORK MODE / select WCDMA (Preferred)/GSM
Good luck .... it worked for me !
My Experia doesn't detect the sim nor the SD card
My daughter has a Xperia Z5 phone. It had been working and all of a sudden the sim card wouldn't work. When you try to call it says "mobile network not available". The SIM works in my other daughters phone and I have tried swapping the SIM's. I took a screen shot if this helps:
That just fixed my daughters phone, thank you. Simple xxx
