Xperia XA not accepting my pin and some other bad experiences.
SOLVED
kjemmo
OK. Here is my experience with my new Xperia XA.
Issue #1: Pin is not accepted
I got i a few month ago and was quite happy with it. Last weekend I went to bed and the battery was around 50% charged when I woke up the battery was drained completely. So I put it in the charger and turned it on after a while but now the pincode is not accepted. The phone just says 'incorrect pin'. I have the same code as on my last phone and know 100% that I have not changed it my self during the night. I do not even know how to change it. So it seems that either there is a bug so the correct pin is not accepted or the pin changed by it self.
Issue #2: Xperia Companion do not work
So a phone changing the pin by it self is annoying, but it must be possible to do a reset of some sort. So I head to the sony website for support and find this guide that instruc me to use Xperia Companion to reset my phone. (http://support.sonymobile.com/gb/xperiaxa/faq/I-cant-unlock-my-screen/)
I install Xperia Companion and follow the guide to do a reset, but I can't complete the guide and get an error instead. So I start trying to resolve that error, but so far no luck.
The error code is: UEStartNoMorePorts L_2384
Issue #3: The support contact page do not work.
At this point i realize that I will not be able to solve this on my own, so I head to Sony support page to get some chat support. But even this seems to be an issue. When I acces the support page the country selecter do not work and the 'contact us link' just sends me to none-working page that I am already on.
Sorry Sony, but this is about the works experience that I have had with any phone and support department. Not only do my phone not work, but any attempt to fix the issue and get proper support has failed. I have spend hours on this and are very disapointed. Please let me know how to proceed.
1 ACCEPTED SOLUTION
kjemmo
I already tried different browser.
I turned out that the country dropdown worked for the Australian version of the site...???
Anyways I managed to get a chat support going after selecting Denmark as my country. The support was not very helpfull though. The supporter had no solutions for the Xperia Companion error and suggested that I tried on another PC or turned my phone in to the retailer.
Now I got stubborn and finally came up with a solution my self. I unistalled all Sony software namely:
  • Sony Mobile Update Engine
  • Xperia Companion
Then in did a registry cleanup with a little software called CCleaner.
Next I reinstalled Xperia Companion and tried to do a Factory reset again. This time it worked.
So if anyone else have this issue please try the above approach.
Sony support staff is useless and I have to say that level of support is terrible. So my journey can be narrowed down to this:
Phone not working > software not working > support website not working > when I finally get support it is useless.
Figured it out my self but spend too many hours in the process.
4 REPLIES 4
Uliwooly
@kjemmo
Try a different browser and/or click here
http://support.sonymobile.com/global-en/contactUs/
kjemmo
  • Xperia Companion
Uliwooly
@kjemmo
So the issue was with your computer and your experience with your Local support wasn't as "helpful"?
Isthatxavier
I am experiencing a bug with my Xperia XA ultra. One week after the previous update, I decided changing my phone's screen lock security from pattern to swipe. It worked fine, but when switching again for swipe to pattern the system crashed. I have factory reset it twice. I have performed two system repairs using the Xperia companion and every time that I go to settings - screen lock and security - and if I select pattern, pin or password, my phone crashes and I cannot unlock it.
In the meantime, I am just using swipe and it works flawlessly. Any idea why?
(I have also tried clearing the security certificates)
Other users are experiencing the same encryption issue but in a different way when their pin is rejected .. please just report this bug
