sound too low
xristos00
sound too low
Hello,
i own xperia XA for about a month. Last days i have a problem with the sound. From heaphones everything is ok but the main speaker is too low.
I have check the volume and the settings and everything seems in order  but the sound is too low. Also i've restarted the phone many times. i've done the update today but nothing changed. With clearaudio on is a bit louder but still too low.
Whats could be wrong?
btw nothing happend like water or crushed on the floor.
7 REPLIES 7
Uliwooly
@xristos00
which music app are you using ?
xristos00
i listen to default app, i also tried the google music but its the same. but its not only with music but general, even alarm is too low
Uliwooly
@xristos00
Settings > about phone > diagnostics > test > test the loudspeaker
you can contact your Local support to get your device inspected.
xristos00
done. its playing but in the same level, its asking me if i hear the sound.
any other ideas?
Uliwooly
@xristos00
xristos00
thx for your time
Uliwooly
@xristos00
anytime, keep us updated.
