Keyboard Vibrate
SOLVED
Ote
Keyboard Vibrate
How to disable vibrate on my keyboard ? I've gone to sounds and xperia keyboard yet I still can't find it.
1 ACCEPTED SOLUTION
profile.country.RO.title
_alexdon_
@Ote I have preloaded xperia keyboard on the X I have at hand, I believe you are using either swiftkey or the one I mentioned. To disable vibrations, go to language and input, select your keyboard, keypress feedback and disable vibration.
alexdon
8 REPLIES 8
Uliwooly
@Ote
Settings > Sound & notification > Other sounds
Ote
Aww . Still don't work. Keep on vibrating hahaha 😞
Uliwooly
@Ote
Open any messaging app > tap the input box > you should see the Settings icon on the left side > settings > more > typing > sound & vibration
Ote
Why I can't find it ? Hahaha ..
Maybe my phone doesn't have that "off keyboard vibrate" feature.
Even at msging app, all I see was notifications setting etc and can't see more > typing > sound and vibration ..
Thanks anyway 🙂 🙂
Uliwooly
@Ote
Open the messaging app > open any conversation > tap on the input box > on the LEFT side of the input box do you see 3 horizontal parallel lines?
_alexdon_
alexdon
Ote
None. There is no horizontal lines nor three horizontal dots on the left side. On the right side yes it has but it only give three options abt messages not sounds or any vibrate modes.
Ote
Yes !! Thanks much @alexdon 🙂
I don't know how I found it but its now fixed hahaha .. Thanks a lot. 🙂
