front camera says 15MP instead og 16MP on my XA Ultra when i check the settings for the front camera
it is normal or it should be exact 16MP for the front facing camera for XA Ultra?
Thanks!
Hi @JackRenz16,
16MP for the front camera is available in the Manual Mode, if you're using SUPERIOR AUTO then 15MP is the highest resolution available. Both 16MP and 15MP for the front camera are 16:9.
I think it might be 15.7 or 15.9 actually, just multiply the resolution numbers.
Hi @JackRenz16,
Thanks for the info.
Cheers!
i would like also to inquire if XA ultra supports USB OTG?
Xperia XA Ultra supports USB host, which allows for the usage of an OTG adapter for example.
Okay, Thanks Emir for those info.
One last, does XA Ultra support Slow Motion Video?
Cheers!
Hey, no worries!
Let me know if there's anything else you're wondering about.
One last Emir, does XA Ultra support Slow Motion Video?
What do you mean by slow motion video more precisely? Do you mean that you want to play back a video you've recorded in slow motion or?
Sorry, I mean to record a video via slow motion and be able to play it back as well
