front camera says 15MP instead of 16MP
SOLVED
JackRenz16
front camera says 15MP instead og 16MP on my XA Ultra when i check the settings for the front camera
it is normal or it should be exact 16MP for the front facing camera for XA Ultra?
Thanks! Slightly_smiling_Face
1 ACCEPTED SOLUTION
Emir1
Hero
Hi @JackRenz16,
16MP for the front camera is available in the Manual Mode, if you're using SUPERIOR AUTO then 15MP is the highest resolution available. Both 16MP and 15MP for the front camera are 16:9.
12 REPLIES 12
profile.country.RO.title
_alexdon_
I think it might be 15.7 or 15.9 actually, just multiply the resolution numbers.
alexdon
Emir1
Hero
Hi @JackRenz16,
JackRenz16
Thanks for the info. Slightly_smiling_Face
Cheers!
i would like also to inquire if XA ultra supports USB OTG?
Emir1
Hero
Xperia XA Ultra supports USB host, which allows for the usage of an OTG adapter for example.
JackRenz16
Okay, Thanks Emir for those info.
One last, does XA Ultra support Slow Motion Video?
Cheers! Slightly_smiling_Face
Emir1
Hero
Hey, no worries!
Let me know if there's anything else you're wondering about. Slightly_smiling_Face
JackRenz16
One last Emir, does XA Ultra support Slow Motion Video? Slightly_smiling_Face
Emir1
Hero
What do you mean by slow motion video more precisely? Do you mean that you want to play back a video you've recorded in slow motion or?
JackRenz16
Sorry, I mean to record a video via slow motion and be able to play it back as well Slightly_smiling_Face
