Bug with DATA connection notification not fixed.
victor91r
Hello! in the new firmware xperia xa ultra (111) not fixed a bug in the application incallui.apk . constantly appears notification on / off data. Even when you switch the flight mode , 4g or just the device is lost or find network.
Tags (2)
70 REPLIES 70
Xperia_XA_Dual
Hello,
i am facing one notification problem,
when ever i turn off my mobile data & at that time or any time i receive any phone call or when i receive any message that Mobile Data Off notification always pop up and show me on my lock screen. i every time clear it but when call coming every time it pop up.
so kindly do needful for this.
Uliwooly
Are you using a VOIP or VoLTE ? test it in >>> safe mode
if possible record it > upload it to youtube > post the link here.
Xperia_XA_Dual
ya i will record it and upload it in YouTube, give me some time.
Thank you
JackRenz16
Hi Guys, any update on this
Thanks Slightly_smiling_Face
victor91r
Russian Xa ULRTA F3211 was updated (build number not changed 36.0.A.1.111)and bug was fixed! Thanks all! Waitin for fix camera bug!
U need to update with Xperia Companion for fix this.
JackRenz16
Okay, Thanks for the info. hope that software updaate is also available on my country, i'll try to update my phone using the Xperia Companion; hope that will fix my issue as well
Cheers!
vhackz
Hi, I'm just wondering on how can I permanently disable the notification on my notication bar about mobile data being disbled. I just preferred to use wifi intead of mobile data so I seldom turn it on, but I alway got this irritating notification "mobile data is diabled" which I have to clear from my notification tray all the time. This is annoying and I wanted it to be fixed please. Thanks
profile.country.US.title
Qatrium
This notification is a part of "Phone services" app, if you disable notifications from this app you may miss other important notification related to basic telephony. I can't think of a way to get rid of this permanently without losing other vital functions.
You may leave the mobile data on anyways and when you activate WiFi it will be disabled automatically, and while you are away from WiFi you can disable background data so apps will not consume data unless you open them yourself.
victor91r
vhackz, u just need to update.
Quester, u not able to turn off notifications of system apps without root.
This bug was fixed in last update(1-2 month ago), and mobile data notification show only once,and no more
Christofer
Champion
Hi all, if anyone still experience this please make sure to update to the latest software version.
