I just got an alert for the .42 update. Does anyone know what difference this update is versus the .283?
it's not worth it, you will have to re-root your phone and go through all that work, just wait for the next update Android 4.0 ice Cream sandwich, we will be able to uninstall preloaded apps w/o rooting or going through a lot of work
nothing important, there are few extra apps (that can be uninstalled) but other than that nothing
Make sure you backup your phone
settings -> privacy -> back up my data and automatic restore should be selected and
Backup & Restore app
Use this links to download the apk
http://forum.xda-developers.com/showthread.php?t=1193802
or
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apkhttp://www.elita-clan.com/downloads/backup_and_restore_v010935.apkor
http://www.mediafire.com/?1n07llajeaoo03y
How to install it
You need to
go to settings -> applications -> check unknown sources
download IO File Manager
https://market.android.com/details?id=org.openintents.filemanager&feature=search_result
download the backup & restore app, transfer it to your SD card, use OI file manager to find it -> tap on it -> install it
Contacts
just to play it safe sync your contacts w/ google if you haven't already
SMS/MMS
if you don't want to use the backup & restore app then
Install "backup SMS" to back up your SMS and MMS to your Gmail
https://market.android.com/details?id=com.zegoggles.smssync&feature=search_result
or your SMS use
"backup & restore SMS"
https://market.android.com/details?id=com.riteshsahu.SMSBackupRestore&feature=search_result
or for your MMS use "Save MMS"
https://market.android.com/details?id=com.schwimmer.android.mmsextract&feature=search_result
Call Logs
And for call logs this is great
https://market.android.com/details?id=com.yang.android.ansta
Ok well my phone is rooted and i have removed system files so I know i can not use OTA and have to use pc companion and update service.
BUT instead of using titanium backup to backup everything and reflash is it worth it?
What are the extra apps or differences?
For now i just froze update service so it stops telling me to update it but just need to know if there is any benefit, if there isn't i will just stay were i am on this version of 2.3.4 im on.
it will stay on 2.3.4 and it comes with macaffee which is pointless and it depends on market that they will add UEFA Champions League etc
why did you removed system files?
Ahh ok don't see much point in updating then. I removed only select system files to gain some storage space seeing as were limited.
I removed some pre-loaded games as i had no interest in playing them as well as some pre loaded applications that i have no intent on using as well.
Worked out well as i now have about 65 user installed apps (including games) and still have 160 mb of internal space free.
Def i'm on the same page as you. Can't wait for that 4.0. Also excited for the playstation suite whenever they decide to release that, im hearing spring of 2012 though
yeah, in japan the Arc and Acro are PS certified
http://www.engadget.com/2011/11/09/sony-ericssons-xperia-acro-and-xperia-arc-get-playstation-certi/
in the mean time, you can use emulators
and also sideload the Playstation app
2.3.4 is supposed to have a fix for the front facing camera that will hopefully enable me to join G+ hangouts with it. The fix is for Google Talk but I expect it should also fix the issue with G+
as well. It also fixes a few os vulenerabilities but probably nothing I'd lose sleep about. I'd consider skipping it too if I wasn't anxious about the ff camera and G+,
McSinned
