My phone (Xperia 5) notifications are turned on all times. I am unable to clear it. Doesn't affect the performance but a bit annoying. I have restarted the phone and turned the notifications off and on but nothing happens. Any help would be appreciated.
Same phone same problem. Really annoying.
Now the dot has just disappeared after few days.
Today I had a missed call on my Xperia 5. After opening the phone app to check the call the notification Dot won't go away. I've cleared the cache and data of the app, I've uninstalled and re-installed app updates, restarted the phone and removed the SIM yet the notification is still there. Has anyone else had this issue?
I also can't seem to upload screenshots here
Yes a bug with the app then. The trick with the pull down notification solved it for now.
Hello everyone and I'm sorry to hear about this.
Google will release an updated version of the Phone app around October 21-25.
A huge thanks to everyone who has reported this and I hope all of you have a great day!
Please fix this the update done nothing
I did have this problem and after few days the dot disappeared, but after next missed call the dot came back and hasn't disappeared since then.
I got the phone app update yesterday, but it didn't help. It seems that the only solution is not to miss any calls.
Its now 28 October, I am still having notification issues. I tried to check for updates but there seemed to be none.
