Battery charging indicator - xperia 5
Tomersonn
Hi all,
in all of the devices I have used in the past, the phone indicates it is using quick charge when quick charger is plugged to the phone.
When I am plugging my xperia 5 to its quick charge, the phone only indicates it is under charging.
Is it ok or do I have a problem with my charger? (I am not using battery care mode).
Thanks.
4 REPLIES 4
Yekollu
Contributor
Quick charge is not supported anymore, as far as I know, instead, we have USB power delivery and is supposed to be faster than Quickcharge.
Jonas
Master
Hi @Tomersonn, welcome to our forum!
As far as I can remember, Xperia devices have never indicated in any way that they are being charged with a fast charger. It has always just said charging on the lock screen and the icon in the status bar had the same look even if you used a Qualcomm Quick Charge 3.0 charger, or a standard charger.
As @Yekollu mentioned, Xperia devices launched with Android Pie (Xperia 1, Xperia 5, Xperia 10 , Xperia 10 Plus and Xperia XZ3) only supports USB Power Delivery which isn't a "fast charging" method, but it will charge faster than, for example, Qualcomm Quick Charge 3.0. The charger you receive with the device called UCH32 is a USB PD charger.
I hope that answers your question! Slightly_smiling_Face
Tomersonn
Thank you Jonas and @Yekollu for the help.
Jonas
Master
@Tomersonn, you're very welcome! Slightly_smiling_Face
Have a fantastic weekend!
