so i have this problem where my phone doesnt produce any sound when playing music, and when being called. I've already put it at its max volume but still no sound. I can only hear sound when im using my headphones and also when i diagnose the speaker i sound normaly .... pls help
I have same problem with my z ultra, yet bluetooth and headsets are working.
Adding to what youve said, ive noticed that i cant change the mono to stereo. And when it changed(automatically), the sound now came back.
Same issue. It is most frustrating. Also, my Facebook app was glitching a lot so I uninstalled it and went to reinstall and it wouldn't do it. My phone is feeling pretty useless without being able to use it for calls or entertainment. Poor user experience.
Try the sound about app. Then select where you want the media to play. Had the same problem with my mum's phone and it worked. Hope it helps
When my xperiaz upgrade to 5.1.1 until now is no sound.what to do.sir?
Thought I had this problem, turned out my bluetooth was on. Just in case anyone is as dense as I was.
I also have that same problem
When I received calls I don't hear anything unless I open speaker
: xperia z no sound ( speaker ) when playing media and general mode but have sound when diagnose
No sounds for Anything except using earphones or speaker
