Xperia UI frozen after coming out from lock screen
SOLVED
tyw7
I find the app switcher and notification bar inaccessible when the phone comes out from lock screen. Swiping down or pressing the task switcher does nothing.
1 ACCEPTED SOLUTION
tyw7
The widget was the issue. Removed it and problem went away. Launcher not the issue.
20 REPLIES 20
tyw7
I've done a factory restore via phone menu but same.
profile.country.RO.title
_alexdon_
Do you use task killers or battery savers?
alexdon
tyw7
I'm going to wait until phone is fully charged.
tyw7
No I don't. But I use a third party skin.
tyw7
I use Launcher 8.
Uliwooly
That's the problem, uninstall it > press and hold power & volume up for 5 seconds and check again
_alexdon_
Please do not double post.Follow uli's advice.
alexdon
tyw7
The launcher worked with Xperia Z though.
I'm removing and I'll report back.
And I'm posting through mobile so I can't edit posts.
_alexdon_
Ok,try to get to the point in one or MAX 2 posts.Keep us updated.
alexdon
