Unknown icon in my status bar
SOLVED
Vio
What does that icon mean, please?
I don't know how it's appeard, and I have not been able to find a list of icons from the status bar on the internet...
Does anyone know how to remove it?
Thanks in advance!
Violette.
(Sorry about my english, i'm french ^^ )
1 ACCEPTED SOLUTION
bras4real
when you have the 'low battery'mode switched on the icon occurs, when the battery is on and below 30%. if i am correct, at that point, the screen brilliance is automatically switched to lowest brilliance level as well
3 REPLIES 3
Uliwooly
I haven't seen this before but since you have your stamina on most likely its a warning that you are almost out of battery
bras4real
Vio
Thank you very much, you were right! Slightly_smiling_Face
Tags (2)
