Unfortunately system ui has stopped after Android 6.0.1 update
Bunny_061
After updated to Marshmallow 6.0.1 the error message pop up "unfortunately system ui has stopped"! The only way that I know to solve this problem is removed the sd card.
How to solve the problem?
Topic edited by Rickard
32 REPLIES 32
Xperia-Z2_User
HI ,
I have been having this issue for almost a month now , this error has decided to show up again now and i'm travelling tommorow and desperately need my phone
I have tried the safe mode and the fone seems to be working fine. My question is , hw can i identify the 3rd party app that is responsible for this crash so i can uninstall it ?
presuming that it's a 3rd party app that is causing this ordeal
Joey08
This message shows up when I try to increase the volume
Fyldecoaster
This solution worked for me.
The Whats new software would definitely seem to be the cause of UI stopping working.
I followed the above advice , frirst removing all the updates then disableing the apWhats new app and on reboot all worked OK. I just hope it stays that way!!
