After updated to Marshmallow 6.0.1 the error message pop up "unfortunately system ui has stopped"! The only way that I know to solve this problem is removed the sd card.
How to solve the problem?
Topic edited by Rickard
1) no sd card installed
2) i have used Xperia companion to repair my phone several times, it keeps coming back
now after a few days the System UI not wortking message keeps coming back. all i know is that Google Chrome does nto work too after I do the repair and everything else works fine for a few days.
I NEED my phone to work, but it keeps happening, please help
Sony Xperia z2
27.02.2017
I have found this is related to the what's new app.
When you get the power off screen long press powder off to go to safe mode.
Then go to settings system update
Reset what's new to factory default. Do not update this software and all is good.
I need to remove the app but is a Sony system app.
System UI has stopped in my device,i can't access my hand set, how to recover from this critics
same problem.... very anoying. Was satisfied about xperia, until this problem came up...
Help us sony, its something with the software
Keep on getting error message "UI not working" having to reset phone all the time.
I find my phone showing message said * system UI has stopped *
try to see if it happens while you are on safe mode
if it does, try to perform software repair using Xperia Companion
I have this problem too. Sent my phone in for repair to Carphone warehouse where I bought it, and they reset the phone. Worked fine for about a month after repair and is now doing the same. Have to restart phone and only works for a short while after, and then does the same. Unfortunately UI Stopped working. This is frustrating. What should I do please. It is a brand new phone.
It has happened to me that after updating an application that I used every day, I have appeared "System UI has stopped", which resulted in my cell stop working completely. I uninstalled that app and the problem was fixed. Although I would like to be able to count on that application again. Does anyone know why this happens and how can I fix it?
GT
i started having the exact same thing , tried repairing software once , it wrked well for a couple of days then it started now to happen again
did anyone found a solution for this ?
