I am bought z1 before 10 days
But i think i have a problem..
In setting in power management gives me time about battery.. 17 hours and with stamina gives me 2 days and 13 hour... Of course when my battery full 100%
But my friend gives him 3 days and 17 hours
And with stamina 9 days. And 15 hours.!!!?
Why do i have very very little time!!!
Do i need to switch my phone???!!
What is the problem.??!!
Plz help me sony!!!!
Topic edited by Rickard
I must not accept all comments,actually I have to "clean" the forum from the disrespectful ones.Anyway,good luck.
Yes, this guy is kind of energetic. But the link you posted is general things you can do to improve your battery life. The problem he has has nothing to do with how he uses the device. I've had the same problem and my battery drained itself in a day or two, also destroying a microSD card. This is not because of erroneous usage, it's because of erroneous overheating and overloading out of nowhere. The normal standby battery life can reach 15-17 days, and 7-9 with mediocre usage in stamina mode.
And if you really think it's acceptable to treat every single problem on this forum via SUS and Factory resets... then there is something very wrong here.
I'm sorry if some of us behave in an angrily fashion, but that is really, literally, all we have heard from Sony thus far. 'Use the SUS and repair your phone'. It means some of us practically have to re-install our phones every week, or every few days. Because these issues appear again after you reset everything.
My advice to the original poster: bring your phone back to the retailer for repair.
I did not post anything about what you said,it is by someone else.And I do not understand why I should not recommend repairing,because more than 50% of the users do not update the phone correctly.
Because repair can't fix hardware problems? It's been suggested so many times in the topic with Touchscreen problems. Even retailers strongly believe it's a software problem. But it's not.
Sincerely,I do not recommend repairing in touchscreen problems,but most of the time,the issues are because of an app,incorrect install of the software,rooting and others.The hardware issues are in another part,where we suggest taking the phone back to service.
How hard is to click on that link and read it all, and focus on the bottom half?
STAMINA mode
It has already been mentioned a couple of times that Smartphone’s use a lot of power, even when you’re not actively using them. All those app’s that you have on your phone may still be running in the background, draining your battery. STAMINA mode is a further development of Extended standby mode and saves wasted battery drain by recognizing when your display is off and turning off functions you don’t need, while keeping the notifications you want. As soon as you wake up your Android Smartphone, everything is up and running again.
Get only the important notices.
With Battery STAMINA mode, Wi-Fi® and data traffic are disabled during standby, but you still receive incoming calls, texts, and alarms. And since everyone has different needs, you can easily customize which app's you want to receive push notifications from even in standby mode. Facebook notifications on or off? It’s up to you.
The STAMINA mode will constantly re-evaluate your usage and update the expected standby time accordingly.
This standby time will completely vary depending on your own personal usage. You may see that when you first start using your handset, the Standby time will be higher than what is expected after you have used the handset for a few days. This is due to STAMINA mode having no previous usage history to estimate from.
If you have a very high usage level, you may only see a slight improvement between having STAMINA enabled and disabled. STAMINA mode is more effective the more often the display is turned off as this is when the power saving features kick in. If the display is rarely turned off, you may not see much improvement in the battery performance.
