- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Sony z3 stuck in airplane mode.
My Z3 will not come out of airplane mode. Tried every thing including a complete reset to basics.
Anyone else seen this ?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I was trying to do a factory reset on this phone. It wouldn't work. I then discovered the airplane mode was on and thought that might be my problem. I found this forum while researching. None of the above worked. But let me share with you what did that I discovered on accident!
I swiped my finger from the top. Had no idea this would even do anything. (I tried to take a screenshot but when I do, it goes back to the regular screen.) When you swipe from the top, a "notifications" tab will be on the left and "Quick Settings" on the right. Select Quick settings. Here I turned off the Stamina, which was apparently stuck on also, as I had previously turned it off in the settings. When I turned the stamina off here, the airplane mode automatically turned off. If it doesn't, I suggest trying to turn the airplane mode off here also.
Hope that helps. Now on to try to figure out why the factory reset STILL won't work... Is it possible the battery has to be above a certain percentage before it will work? hmmmmm...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
hello .I have same problem and i fixed it . All you need to doo is :go settings and backup&reset/Factory data reset /Earse internal storage/ reset phone/ earse everything and all is done . Hope i helped you
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hello.
I recently bought a Z3 that had the same problem but with WiFi and Bluetooth, changed that unit for a new one and after almost a month airplane mode problem appeared.
I have tryed the factory reset and the Companion repair feature and nothing worked.
Any news on this problem, SONY?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I'm very sorry to hear that
I'm afraid this sounds hardware related but if possible, also try the phone with another SIM-card and see if that helps. If not, i recommend that you contact a service centre or your Local support for assistance.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thank you very much for the fast answer.
I tryed two brand new SIM-cards, I hoped for a fast fix.
Tank you again and have a nice day.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
i Have the same problem, why is this issue cant be solved
ill never ever purchase a sony phone again
