Sony Xperia Z HDMI Cable/Adapter [HELP]
РЕШЕНО
ScottUzoho
Посетитель
I have a Sony Xperia Z and I used to have a Sony Xperia S. I used to use the HDMI cable to connect it to my TV all the time to watch films and send emails etc. however with the Sony Xperia Z I cant seem to find any working HDMI cables - I can only see adapters. I'm not sure what to buy to plug into the adapter or even if the adapter will work and the one for the Sony Xperia S doesn't seem to fit. Thanks.
If you know or have one I would really appreciate links to the adapter or/and cables i need to buy to get the HDMI cable working.
If you need to get an adapter I would really appreciate if you could send me a link the the cable that will fit into that specific adapter due to me buying 2 and them not fitting.
1 УТВЕРЖДЕННОЕ РЕШЕНИЕ
Утвержденные решения
Arjun
Опытный
Hi there xperia z needs a mhl adapter in order for hdmi to work
The mhl cable for samsung galaxy s2 works perfectly with xperia z you can buy from http://www.amazon.com/Samsung-MHL-HDMI-Adapter-Packaging/dp/B005LGUDKK or you can search for it on the internet
5 ОТВЕТ 5
Arjun
Опытный
Arjun
Опытный
Here is a video explaining how to use mhl adapter http://www.youtube.com/watch?v=RHa56Dm2j_8
ScottUzoho
Посетитель
Thanks guys. Really appreciate the links. I think I'll get the galaxy one then. Do you know what type of hdmi cable fits into the adapter (is it just the default hdmi cable)
Thanks again.
Arjun
Опытный
Yup a normal hdmi cable would work with it
ScottUzoho
Посетитель
Thanks! Perfect and really appreciate your help man.
