SD Card issue
SOLVED
entwistlesj
SD Card issue
I woke this morning to find a notification saying it was safe to remove the sd card. Firs off I didn't unmount it.
So I took it out and replaced it. Then got a message saying "sd card damaged. Try reformatting"
this didn't work either.
So I restarted the phone. Now it refuses to recognise the presence of a card at all?
anyone know what to do?
1 ACCEPTED SOLUTION
GeoffH
Enthusiast
it sounds like it has failed - what make is it ?
as a last resort before sending it back you could try the sd format utility for PC, a link was posted on another sd thread here
I wouldn't hold my breath though as it sonds like it failed
3 REPLIES 3
GeoffH
Enthusiast
entwistlesj
Yes I tried to format it in my Mac but the computer won't recognise the card so it's going back.
fredtls31
Hello
looks like you're not the only one geeting this issue and that the last version of the SW released is increasing the number of occurence => check this post
/t5/Xperia-Z-ZL-ZR/Xperia-Z-SD-card-killed/td-p/399425
