Are you using battery savers or task killers?
Ok,glad it is ok.Set a correct answer for others to see.
Ok,just select your post as correct answer.Under the reply button you have it.
I have put my fone on upgrade but the home screen keeps loading and thing happened. I have looked your forum and find out we need to upgrade through the pc. I have tried it. But the phone is not detecting in the upgrade software. plz provide me the detail steps for connecting the usb and we need to press the power button with volume down key. but it not getting me to the next step "confirm".
What are you using for repair/update?Pc companion or sony update service?
