My phone keeps restarting over and over and over...
TheRealWitblitz
I've had my Z2 for about 3 weeks, and now this is happening. When I first got the phone it was obviously fine, a few days later I updated the firmware with PC Companion. And it was good for about another week. But since today the phone keeps restarting over and over, I can't even get the time to power it down.
Why is this happening?
32 REPLIES 32
Sam
Legend
Legend
@Enteng - That is certainly not normal, did you cut the SIM yourself, is it actually a nano SIM or is it originally a micro SIM?
What are your thoughts about this forum? Let us know by doing this short survey.
wan79
i also have the same problem..
SayeedHamid
I am from India and yesterday ther was a software update notification from xperia centre on my phone. I did the update and fater that my phone has refused to work. It's restarting by itself after booting and its not going to the homscreen.
Sam
Legend
Legend
@SayeedHamid - Sorry to hear that, it sounds like the update has not loaded correctly onto your handset. With this being the case I would advise running a firmware repair:
1. Download the PC Companion software from http://www.sonymobile.com/gb/tools/pc-companion/
and install it on your PC.
2. Install and open PC Companion then select Support Zone.
3. Phone Software Update.
4. Start.
5. Repair Phone
6. Continue
7. Accept data removal
8. Next
9. Wait for prepare
10. Select Phone
11. Follow the connection steps
SayeedHamid
Hi Sam
Thanks for your reply. I did Try with PC Companion. Still It Doesn't work. Still it's the same.
Sairam6783
Hi,
Having similar issues after the Software update that was released on Friday, phone keeps restarting no matter what you are doing with it, I mean the restarting is not restricted to a particular activity. I tried the normal backup and restore, no use, then I tried the repair from PC Companion still no use, not sure what is happening, please provide a response.
Regards,
Sairam.
SayeedHamid
I had taken the phone to Xperia care. They installed the software but still its the same. Now they are saying that the board has to be replaced and my phone is out of warranty. They are not able to trace what has caused this. When i contacted sony customer care they are saying as my phone is out of warranty they can't help on it.
ANWARIDIS
HI
I HAVE SONY XPERIA Z2 AND I HAVE SAME PROPLEM ITS KEEP RESTARTING AND I CANT DO ANYTHING WITH IT
wan79
4. Start.
5. Repair Phone
6. Continue
8. Next
9. Wait for prepare
10. Select Phone
The good solution for me for this problem
19667
Contributor
yeah i also had that problem so i repair my phone using PCC no its over now i can working normaly
