Locked out of my xperia z by prey?
SOLVED
NathanCaddy
Can anyone help me get into my phone? Apparently prey is a security app and is notoriously hard to remove, however, it should not be imposiible. I tried to remove the app from my phone and then online on their control panel, this was not a good move as it now has locked my phone and will not recognise the password as i have deleted the phone profile from there control panel.
I have tried a soft and hard start to no avail?
Anyone........please
Nathan
1 ACCEPTED SOLUTION
Uliwooly
you have 2 options
1) keep trying to remember the password
or
2) repair your phone with SUS, this will delete everything on the phone except for pictures, videos and/or music
6 REPLIES 6
Uliwooly
you have 2 options
or
Uliwooly
NathanCaddy
1/ Cant get into the phone as the password is not recognised by the prey website as I have deleted the phone from the control panel?
2/ can you repair the phone with SUS even if you cant get it unlocked?
Cheers Nathan
Uliwooly
yes you can repair it, just turn it off and use SUS not PCC
NathanCaddy
Thanks, hopefully got rid of that invasive app. Thanks again Nathan
Uliwooly
anytime
keep in mind that you do not need this apps
taskillers
task managers
antivirus
ram apps
battery apps
booster apps.
