Location based wifi
SOLVED
Jonah72
New
Location based wifi
I can't seem to get this to work. GPS is on, have cleared the data from the app. It doesn't switch wifi off when I leave a registered area (don't think it's supposed to) and doesn't switch it on when return to a resisted area. Have searched forums and can't find an explanation.
1 ACCEPTED SOLUTION
Johan
Master
Try clearing data for the Location based Wi-Fi application in the phone. This will delete all your saved networks for this feature.
Settings > App's > All > Location based Wi-Fi > Clear data.
Then try again.
This service runs on mobile triangulation not GPS, so make sure that you network operator supports this.
6 REPLIES 6
Johan
Master
I haven't been able to replicate this, seems to be working just fine in my Xperia Z1 running on the .257 software.
Which build number are you running on?
(Settings > About phone > Build number)
Jonah72
New
Am running the. 257 software
Jonah72
New
Didn't work before the update either
Johan
Master
Then try again.
Jonah72
New
Have tried clearing data from the app. I am on T Mobile in UK, not sure how I check they support this
Jonah72
New
Problem solved, checked coverage from T Mobile, seems we are in a bit of hole. Wifi switching on if I stand on the other side of the road!!!!
