I can't answer calls
SOLVED
kristineg
I'll see the call coming in on my Xperia Z3 but even when I swipe left to answer, it lags and then I eventually miss the call.
Does anyone else have this problem and hopefully a solution?
1 ACCEPTED SOLUTION
kristineg
Yes, the same thing occurred. However, I "fixed" this by being more patient when I answer the phone and swiping "answer" slower to allow it to register.
Not a great solution but it works!
10 REPLIES 10
profile.country.RO.title
_alexdon_
Can you check if the same occurs in safe mode?
http://talk.sonymobile.com/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008
alexdon
kristineg
stockyvillage
Contributor
Set the phone up so it answers when you put it too your ear..Settings /motion turn motion on
ruffruff
Having the same issue on my first hour of the phone. Quite surprised by this bug and that I am not alone.
candylove13
I have the same problem with my z3, cnt swipe to answer a call.any solution sony support.this is so stupid dnt u think.pls fix this bug. This is crazy i bought a phone that doesn't answer a call. **bleep**
dandy63
Leader
Hi @candylove13 , can you explain a bit further....for example when a call comes in can you see the callers ID or is the screen just black Thinking_Face
candylove13
Hi... During the call i can't swipe the answer icon..the green one to the right no matter how much i try.i can drag the icon to right but nothing happens and then i missed the call. And also i experience difficulties in making calls.i tried the solution i read from a forum that i need to register again to a network provider on network setting.after a while i can make a call and then it will happen again....it is so frustrating.my friends told me I'm always out of coverage but i'm not..i get 3bars to full bar signal most of the time.i tried to put my sim in other cellphone and i had no problems.so i guess the problem is my z3.i hope you can help me fix my problem asap.thanks
dandy63
Leader
Hi, there are a couple of things to try....the first is called SAFE MODE....this will see if there is a problem with a 3rd Party App that you have installed (if you have) interfering with your phone, if your phone works perfectly whilst running in Safe Mode you know it is this.....the 2nd thing to do is a PCC REPAIR, basically repairing your phone BUT before doing this you must back up your phone...may sound all very complicated but if you follow the instructions you will be fine, i've added the links below to these but try the Safe Mode first :smileysmileywink:
http://support.sonymobile.com/us/tools/pc-companion/
http://support.sonymobile.com/global-en/tools/bridge-for-mac/ http://talk.sonymobile.com/thread/36355
http://talk.sonymobile.com/t5/FAQ/Backup-amp-Transfer/td-p/407253/jump-to/first-unread-message
kugie
You are NOT imagining this and I do NOT believe it is anything you have done to your phone. SONY had NOT bothered to fix it either as I have a Xperia Z5 compact and have the same problem. VERY FRUSTRAITING !!!!!! I am currently going to try the one fix mentioned above that turns on smart call handling where it answers when brought up to your ear. Haven't had a chance to prove it works yet. On this Xperia Z5, I went into 'settings', and then 'call'. In 'call settings' the very first choice is 'Smart Call Handling'. I turned it on and we shall see how it works!  SONY should be embarassed to have not figured this out and came up with a FIX  imediately. It obviously isn't just the screen as you well know because it 'senses' my fingers every other time for every other purpose. Just NOT to answer a call.
