How to screen capture on Z2
SOLVED
Lonavla
1 ACCEPTED SOLUTION
Lent2019
I just hold the power botton and the option comes up under shutdown and restart.
I don't think it is part of any app. but good question.
4 REPLIES 4
Daniel1
Hi @Lonavla, Let me see if I can help you out here.
I have translated your question to English as this is an International forum, please post any replies in English and it will be easier for me and other users to assist you.
If you want to record the screen I would recommend you to look at Play Store and search for "Screen recording" or such. Find a application that suits you the best.
Let me know if you have any further questions. Slightly_smiling_Face
Lent2019
Lonavla
Thank you lent2019.
sorted.
Daniel1
@Lent2019
That is totally correct, messed up the android versions here. This feature is not available in our newer phones so forgot that one. Thank you for clarifying and helping out here! Slightly_smiling_Face
And @Lonavla I'm glad your problem got solved. Slightly_smiling_Face
Let me know if there is anything else I can do for you.
