Heart rate sensor
SOLVED
zeeuwke
Heart rate sensor
hello There, i bought the  xperia Z1because off its ipx features and to use it as a heartrate monitor during sports. as I used to do with my samsung galaxy S2. however the bluetooth heartrate sensor doesn't function on the xperia Z1.
does anyone know if it is a common problem withe the software or is it a hardware problem.
( by the way, it is a heartrate sensor from ZEPHYR)
1 ACCEPTED SOLUTION
zeeuwke
hi everybody, thanks for the input. the issue has been solved. my runtastic app. chooses as default for  searching for a bluetooths smart (4.0) device. in the setting I changed that into bluetooth 2.0. problem solved Slightly_smiling_Face
4 REPLIES 4
Uliwooly
There are seems to be certain issues with ANT+
Alexander1
Champion
Make sure that your sport/fitness application supports ANT+. For instance sport/fitness apps like Endomondo, SportyPal, iMapMyRun, Google Mytracks and so on supports ANT+.
zeeuwke
yusufsalie
Hi what heart rate monitor are you using? I have the same problem however i decide to use the garmin heart rate monitor which works better with selfloops.
