Cannot Delete Text Message Conversations
CheeseyBiscuit
I cannot delete any SMS messages on my Xperia Z1 Compact. I have tried multiple methods (and apps) but the only one that appears to work is deleting individual messages - which with almost 25k texts saved up I am not prepared to do.
I have 'Delete old messages' app and have been using it for a while assuming it deleted messages for me but turns out it hasn't worked properly (hence so many texts)
Last resort I will backup everything but text messages and restore my phone, but are there any other options in the meantime?
9 REPLIES 9
Uliwooly
Open the messaging app > menu > delete conversation > select all > delete
Jake-SonyXperia
Champion
Hi CheeseyBiscuit,
Welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
You may need to clear the data from the App first and then try deleting conversation threads.
Menu > settings > Apps > App > Messaging > Clear Data
let us know how you get on.
CheeseyBiscuit
I tried that with little success, so decided while my phone was charging overnight to start the delete process then just leave my phone so the screen will shut itself down after a minute or so. It has appeared to have worked, but must have taken more than half an hour (as this is the most time iv sat and waited for it to complete the process before deciding it wasn't working).
Just a shame the app to remove anything over a month old doesn't work, and i have to wipe everything from each contact.
Thanks for your help anyway Slightly_smiling_Face
Jake-SonyXperia
Champion
No problem, the only thing I can suggest would be performing the Backup as you stated and performing a factory reset, as it could simply be a glitch.
art0912
Download textra sms . Quick deletion of whole thread sms.
AlbanThurstonLo
I really dislike Sony's poorly integrated Messaging app for SMS, as run on the Xperia Z1.   ( My Android version is 5.0.2)
How do I eradicate Sony's Messaging app from my phone, and substitute it with MyPhoneExplorer, freeware which integrates calendar, contact and SMS functions far more intuitively?
I am not paid by MyPhoneExplorer, unlike Sony software engineers who are paid by.... erm Sony,  Any contributions of clear, objective, easily understood step-by-step instructions will be warmly appreciated.
Alban Thurston, London
VasuS
I downloaded Textra, it shows as deleted in this app. But if i start the original app, it still shows the deleted messages. This is terrible, please help
GEORDIEC1
Messaging is not on my apps so I cannot delete texy messages which after I have deleted them keep coming back on Please Advise Thnk you
Uliwooly
@GEORDIEC1
which messaging app are you using?
