Hello,
I have installed the app Sony SBH52 on my Samsung Galaxy note 3 with Android 4.3 .
The App is installed, but i can not open it .... is not among the icons of installed applications...why?
Can you help me?
Many thanks
Hi and welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
The app for SBH52 doesn't have any icon of its own. To access the app you also need to install Smart Connect: https://play.google.com/store/apps/details?id=com.sonyericsson.extras.liveware. You will also be able to access the SBH52 app from the notification bar when Smart Connect is installed.
Wow....many thanks! đ
