XZ2 Compact - remove network lock when there's no prompt
profile.country.AU.title
Mark1900
New
My new XZ2 Compact has a network lock according to the Service Info (see pic). I have the official unlock code but find no way to enter it. There is no prompt to do so after putting in a SIM (any SIM, different networks). Searching the web suggests that entering #987654321# should trigger a prompt, but that also does not work.
Any help is much appreciated. Thanks.
4 REPLIES 4
profile.country.PH.title
MarlonUk1
hello @Mark1900
is the new sim card from a different network provider? does it acquire signal when you insert it? , try to insert the simcard, and restart your device
Mark1900
New
Hi @MarlonUk1.
Thanks for your response. It's a new phone and I tried multiple sims from several operators. No signal (bars). Restarting with or without sims gives no change in symptoms. Cheers.
profile.country.NL.title
Strampke
Try this:
Goto settings, search reset, choose reset network settings, reboot.
The SIM card should be re-initialised by your provider, auto.
Mark1900
New
Tried it, no change.
Thanks.
