Xperia XA - Replace Outer Glass
PM1705
I need to replace the outer glass from my Xperia XA, can it be removed from the front easily or do I need to remove the back cover and completely dismantle the phone??
Thanks..
1 REPLY 1
Jake-SonyXperia
Champion
Hi @PM1705,
Welcome to the community,
In this case, we do not suggest performing this task yourself as you could cause damage to the device and you would hold no further warranty on the product.
I suggest you contact Customer Care and inquire about this type of repair directly.
Use my signature below to find contact details.
Let me know how you get on.
