What's the latest software and firmware for XA Ultra
SOLVED
JackRenz16
Hi Guys;
What's the latest software and firmware for XA Ultra?
Thanks! Slightly_smiling_Face
1 ACCEPTED SOLUTION
profile.country.RO.title
_alexdon_
6.0 is the latest available, 6.0.1 is not available for any X range as @Aidylucas mentioned. I will lock this thread now as there is no need for another thread on when do we get updates.
/t5/Software-Updates/Android-6-When-are-we-getting-Marshmallow-Which-Xperias-will-be/td-p/1033227
alexdon
9 REPLIES 9
_alexdon_
According to xperifirm, it's 6.0:
Device: Xperia XA Ultra (F3211)
CDA: 1302-5030
Market: Nordic Combined
Operator: Customized NOBA
Network: GENERIC
Version: 36.0.A.1.111 / R5A
alexdon
Riand
Xperia XA ultra (F3216)
6.0
Build 36.0.B.1.111
1adrian1
Contributor
No x range device has 6.01
JackRenz16
Thanks for the info guys! Slightly_smiling_Face
mine has 36.0.A.1.111 but i have android 6.0.0
how can i update it to 6.0.1? due when i tried to check for software update, it is telling me it's the latest version for 6.0.0
Cheers!
_alexdon_
alexdon
Brian101
Just bought xa ultra and my phone detects 36.0.b.1.111 as the latest version via xperia companion or software update on the phone. Is this the latest version? I want to install the latest version since basing on this forum there are issues found on old fw versions.
Thanks.
sayan
You are from which country ? Actully its depands on your country.
Brian101
In asia (thailand) if this is the latest, does this version include the latest fixes?
_alexdon_
@Brian101 Read this thread, do not create others.
alexdon
