Google play language changed after firmware update
SOLVED
esergen
My xperia xa language is turkish. After firmware update it changed to english, how can i change it to turkish back..
1 ACCEPTED SOLUTION
esergen
Solved after resetting phone from sony pc app. Thanks..
8 REPLIES 8
Uliwooly
was it only the playstore or the phone itself? did you changed the region/country on any app?
humpity
Settings>Language&Input>Language.
esergen
Only play store language changed, phone language is turkish. How can i do?
esergen
After firmware update begins memory card disconnected problem then i do factory reset. After that memory card problem solved but play store language changed to semi turkish semi english, phone language is turkish..
humpity
Playstore follows you account.
Settings>Apps>(show system) >Google Playstore>Clear Cache+Clear Data.
Restart phone. You may have to remove your account and add it back to your phone.
esergen
I 'm trying now..
esergen
I cleaned play services and play store cache and data both, after that restart phone but nothing changed, same problem continues..
esergen
