I've noticed that, when I press my power key to unlock my phone, there is a (seemingly-increasing) delay before it actually happens.
This is probably due to you removing the back cover
http://talk.sonymobile.com/t5/Xperia-XA-XA-Ultra/Back-cover-removal/m-p/1185967
@Polly13 wrote:... I'm trying to remove the back cover so I can take the battery out, and it feels like I'm damaging the phone! Shouldn't it just pop out or something?
@Polly13 wrote:The battery is non-removable? Nobody told me this,...
Get your phone inspected by your Local support
Well, for a start, I never actually did remove it.
Also, that was a month ago; this delay issue has only started in the last couple of days.
Either or, contact your Local support to get it inspected, if you indeed removed the back cover it will void the warranty.
