TV BRAVIA - Aggiornamento del firmware alla versione 6.6555
https://www.sony.it/electronics/support/lcd-tvs-android-xf90xx_x90xxf-series/kd-49xf9005/downloads/0...
Vantaggi e miglioramenti dall'aggiornamento precedente
  • Migliora la reattività del TV all'accensione dalla modalità standby
Modelli applicabili
Queste informazioni sono valide per i seguenti modelli di TV:
  • KD-43XG8305
  • KD-49XG8305
  • KD-49XG8377
  • KD-43XG8388
  • KD-49XG8388
  • KD-43XG8396
  • KD-49XG8396
  • KD-43XG8399
  • KD-49XG8399
  • KD-49XG9005
  • KD-55AG8
  • KD-65AG8
  • KD-43XG8096
  • KD-49XG8096
  • KD-55XG8096
  • KD-65XG8096
  • KD-75XG8096
  • KD-43XG8196
  • KD-49XG8196
  • KD-55XG8196
  • KD-65XG8196
  • KD-65AF8
  • KD-55AF8
  • KD-75XF9005
  • KD-65XF9005
  • KD-55XF9005
  • KD-49XF9005
  • KD-65XF8796
  • KD-55XF8796
  • KD-49XF8796
  • KD-43XF8796
  • KD-65XF8599
  • KD-55XF8599
  • KD-49XF8599
  • KD-43XF8599
  • KD-85XF8596
  • KD-75XF8596
  • KD-65XF8596
  • KD-55XF8596
  • KD-49XF8596
  • KD-43XF8596
  • KD-65XF8588
  • KD-55XF8588
  • KD-49XF8588
  • KD-43XF8588
  • KD-65XF8577
  • KD-55XF8577
  • KD-49XF8577
  • KD-43XF8577
  • KD-65XF8505
  • KD-55XF8505
  • KD-49XF8505
  • KD-43XF8505
  • KD-70XF8305
  • KD-60XF8305
  • KD-55XF8096
  • KD-49XF8096
  • KD-43XF8096
  • KD-65XF7596
  • KD-55XF7596
  • KD-49XF7596
  • KD-43XF7596
  • KDL-49WF805
  • KDL-43WF805
  • KDL-49WF804
  • KDL-43WF804
  • KD-77A1
  • KD-65A1
  • KD-55A1
  • KD-75XE9405
  • KD-65XE9305
  • KD-55XE9305
  • KD-75XE9005
  • KD-65XE9005
  • KD-55XE9005
  • KD-49XE9005
  • KD-75XE8596
  • KD-65XE8599
  • KD-65XE8596
  • KD-65XE8588
  • KD-65XE8577
  • KD-65XE8505
  • KD-55XE8599
  • KD-55XE8596
  • KD-55XE8588
  • KD-55XE8577
  • KD-55XE8505
  • KD-55XE8396
  • KD-55XE8096
  • KD-49XE8396
  • KD-49XE8099
  • KD-49XE8096
  • KD-49XE8088
  • KD-49XE8077
  • KD-49XE8005
  • KD-49XE8004
  • KD-43XE8396
  • KD-43XE8099
  • KD-43XE8096
  • KD-43XE8077
  • KD-43XE8005
  • KD-43XE8004
  • KD-100ZD9
  • KD-75ZD9
  • KD-65ZD9
  • KD-49XD8305
  • KD-43XD8305
  • KD-55XD8005
  • KD-49XD8005
  • KD-43XD8005
  • KD-49XD8077
  • KD-43XD8077
  • KD-49XD8088
  • KD-43XD8088
  • KD-49XD8099
  • KD-43XD8099
  • KD-65XD7504
  • KD-65XD7505
  • KD-55XD7004
  • KD-49XD7004
  • KD-55XD7005
  • KD-49XD7005
  • KD-50SD8005
168 RISPOSTE 168
sonysta
Campione
Non capisco questa fissa del cambio lento dei canali...ho 5 televisori in casa di 4 marche diverse ( purtroppo e non per volonta mia ma... di Sony! ) e solo uno Sony android ( il migliore..of course) di almeno 3 generazioni di LCD il più vecchio ha ancora la retroilluminazione a tubi ebbene...il tempo di cambio canali del DTT è praticamente identico in tutti non vedo differenze tra uno e l'altro probabilmente con con un cronometro al 1000esimo di secondo troverei qualche differenza ma sarebbe da fobico questa maniacale ricerca della velocità...sembra che debbano morire tutti da un momento all'altro!
Magari è davvero un po' lento, ma sarebbe da capire perché e quindi da cosa dipenda la lentezza.
sonysta
Campione
@Marino.Manolo
Sicuramente qualche caso di lentezza c'è e sicuramente c'è qualche problema ma dato che sono in tanti a lamentarsi di una cosa per me inesistente volevo solo fare un discorso in generale.
Secondo me le variabili per capire "lento" o "meno lento" nel cambio Canale sono troppe, difficilmente ormai qualcuno arriva direttamente dal Tubo Catodico e ci possono essere Sintonizzatori più veloci e meno veloci, ma credo dipenda anche dall'eventuale cambio di Mux a seconda del Canale che vogliamo vedere, del suo numero (siamo sicuri che non sia solo l'attesa per l'eventuale inserimento del secondo o terzo numero che potremmo voler digitare per il Canale scelto?), e per il tipo di Canale di destinazione quindi se SD, HD, FullHD, 4K, qui le informazioni che il TV (il Sintonizzatore) deve ricevere prima di mostrare il Canale selezionato possono influire in quanto sempre maggiori in relazione alla qualità del Canale stesso.
sonysta
Campione
@Marino.Manolo
ma proprio perchè chi arriva dall'analogico e dal tubo catodico è sempre meno che non capisco in rapporto a cosa si stabilisce che un TV è lento...ripeto io ho 5 TV di 4 marche diverse di epoche diverse ma il tempo del cambio canali e parlo del DTT è praticamente identico per tutte...ripeto...in base a cosa si stabilisce che un TV è lento?
In base "alla propria idea" di lentezza o velocità, e da qui le variabili...
sonysta
Campione
Eh no perchè l'idea non comporta prova! Se io devo dire che qualcosa è più lento o più veloce devo confrontarmi con qualcosa di simile che abbia simili caratteristiche  altrimenti rimane solo un 'idea.Devi avere un confronto con qualcosa altrimenti è un discorso di lana caprina...
Non ho detto che è una prova ma solo che probabilmente la lamentela arriva da un'idea sbagliata, un'esperienza diversa o anche solo un "ricordo errato", sai quante volte le persone mi giurano che "è così", poi vai a verificare e...
sonysta
Campione
Eh lo so lo so...però ti rendi conto che cosi è aria fritta.
Flamerone
Però è così @sonysta . Tutti si lamentano di questa cosa e non ho mai capito per quale motivo. Come se uno vedesse sempre la tv in zapping. Tra l'altro con i contenuti che vengono trasmessi lo zapping....per favore!!! Bisognerebbe fare un tutorial sull'utilizzo della guida che ben pochi hanno capito a cosa serve veramente.
PS. Poi magari hai un TCL che cambia canale in 1 secondo ma se ti sposti rispetto al centro di 45 gradi a destra o sinistra vedi il pannello tutto bianco 😁 oppure ogni tanto mentre navighi nei menù si incasina e si riavvia da solo...come accade alla tv di un mio vicino!!!
