TV BRAVIA - Aggiornamento del firmware alla versione 6.6555
https://www.sony.it/electronics/support/lcd-tvs-android-xf90xx_x90xxf-series/kd-49xf9005/downloads/0...
Vantaggi e miglioramenti dall'aggiornamento precedente
  • Migliora la reattività del TV all'accensione dalla modalità standby
Modelli applicabili
Queste informazioni sono valide per i seguenti modelli di TV:
  • KD-43XG8305
  • KD-49XG8305
  • KD-49XG8377
  • KD-43XG8388
  • KD-49XG8388
  • KD-43XG8396
  • KD-49XG8396
  • KD-43XG8399
  • KD-49XG8399
  • KD-49XG9005
  • KD-55AG8
  • KD-65AG8
  • KD-43XG8096
  • KD-49XG8096
  • KD-55XG8096
  • KD-65XG8096
  • KD-75XG8096
  • KD-43XG8196
  • KD-49XG8196
  • KD-55XG8196
  • KD-65XG8196
  • KD-65AF8
  • KD-55AF8
  • KD-75XF9005
  • KD-65XF9005
  • KD-55XF9005
  • KD-49XF9005
  • KD-65XF8796
  • KD-55XF8796
  • KD-49XF8796
  • KD-43XF8796
  • KD-65XF8599
  • KD-55XF8599
  • KD-49XF8599
  • KD-43XF8599
  • KD-85XF8596
  • KD-75XF8596
  • KD-65XF8596
  • KD-55XF8596
  • KD-49XF8596
  • KD-43XF8596
  • KD-65XF8588
  • KD-55XF8588
  • KD-49XF8588
  • KD-43XF8588
  • KD-65XF8577
  • KD-55XF8577
  • KD-49XF8577
  • KD-43XF8577
  • KD-65XF8505
  • KD-55XF8505
  • KD-49XF8505
  • KD-43XF8505
  • KD-70XF8305
  • KD-60XF8305
  • KD-55XF8096
  • KD-49XF8096
  • KD-43XF8096
  • KD-65XF7596
  • KD-55XF7596
  • KD-49XF7596
  • KD-43XF7596
  • KDL-49WF805
  • KDL-43WF805
  • KDL-49WF804
  • KDL-43WF804
  • KD-77A1
  • KD-65A1
  • KD-55A1
  • KD-75XE9405
  • KD-65XE9305
  • KD-55XE9305
  • KD-75XE9005
  • KD-65XE9005
  • KD-55XE9005
  • KD-49XE9005
  • KD-75XE8596
  • KD-65XE8599
  • KD-65XE8596
  • KD-65XE8588
  • KD-65XE8577
  • KD-65XE8505
  • KD-55XE8599
  • KD-55XE8596
  • KD-55XE8588
  • KD-55XE8577
  • KD-55XE8505
  • KD-55XE8396
  • KD-55XE8096
  • KD-49XE8396
  • KD-49XE8099
  • KD-49XE8096
  • KD-49XE8088
  • KD-49XE8077
  • KD-49XE8005
  • KD-49XE8004
  • KD-43XE8396
  • KD-43XE8099
  • KD-43XE8096
  • KD-43XE8077
  • KD-43XE8005
  • KD-43XE8004
  • KD-100ZD9
  • KD-75ZD9
  • KD-65ZD9
  • KD-49XD8305
  • KD-43XD8305
  • KD-55XD8005
  • KD-49XD8005
  • KD-43XD8005
  • KD-49XD8077
  • KD-43XD8077
  • KD-49XD8088
  • KD-43XD8088
  • KD-49XD8099
  • KD-43XD8099
  • KD-65XD7504
  • KD-65XD7505
  • KD-55XD7004
  • KD-49XD7004
  • KD-55XD7005
  • KD-49XD7005
  • KD-50SD8005
168 RISPOSTE 168
Charly410
Collaboratore
@Nejiros
Solo per essere precisi ..
Non appena inserisci la USB il tv rileva un aggiornamento.. Visualizzi una barra di caricamento che controlla integralità del firmware  .. Se è giusto .. Esce una nuova barra ti fa caricare il firmware .. In tutto in 15 18 minuti prima del riavvio  ..
Nejiros
Membro
OK, fatto, ora è andato......cmq metto la chiavetta a TV acceso e parte subito il caricamento(in questo caso acquisisce il file dalla chiavetta) poi si spegne e alla riaccensione inizia a caricare il firmware, si spegne e si riaccende un pò di volte, fa il riavvio e fine.....
Al momento non noto nulla, il cambio canali era lento e lento è rimansto 😅 come è rimasta anche la lentezza generale ma è sempre stata così.....nonostante tutto a me Android piace molto come sistema....
dannix
Membro
buonasera la cosa strana è che sul mio xg8396 non risulta aggiornamento dovrei inserirlo con la chiavetta, leggevo che il software update arriva in ritardo vi risulta??? ma riguarda il passaggio da Android 8 al 9 ???
@dannix il TV può ancora non rilevarlo via rete, se vuoi aggiornare scaricalo e procedi tramite USB:
https://www.sony.it/electronics/support/lcd-tvs-android-xg83xx_x85xxg-series-kd-43-49-/kd-43xg8396/d...
Android TV 9 forse, quasi di sicuro, il tuo modello non lo riceverà.
ErVikingo
Collaboratore
@Marino.Manolo non ho detto che il 2.4GHz abbia migliorato sensibilmente la questione, ma solamente che oltre allo statico e il canale in automatico ho disattivato il 5GHz perché mi e troppo distante dal TV.
Poi cosa abbia migliorato il tutto non saprei, forse un aggiornamento da parte del gestore?
No l'ho detto io, perché la 5 GHz poteva essere molto meno performante della 2,4 GHz.
ErVikingo
Collaboratore
Ricordo @Charly410 tant'è che stavo in procinto di acquistare un ripetitore, ma poi per una cosa, o per un'altra, son passati alcuni giorni, poi è andato tutto per il meglio.
Vai a capire.
gioagril
Membro
Certo che il cambio canale nello zapping anche solo sul dtt è veramente molto lento, ho un tcl android e ci mette un quarto del tempo, tanto che ormai lo uso solo con decoder collegato
Bruxk120
Membro
Salve a tutti!
Volevo condividere con voi la mia esperienza riguardo all'aggiornamento del mio TV 43XG8396.
Ho aggiornato ieri tramite pennetta usb.
L'aggiornamento è andato a buon fine e non ho rilevato problemi alla fine della procedura ma se devo essere sincero non ho avuto modo di notare particolari miglioramenti.
Forse è minimamente migliorata la reattività del telecomando che sembra rispondere più velocemente ma per il resto il cambio di canale è rimasto lento e ho il dubbio che la lentezza sia anche aumentata anche se di poco.
Tutto il resto, come già detto, mi sembra veramente rimasto invariato.
Grazie a tutti e buona giornata!
dannix
Membro
salve io in cucina ho un Sony xg8396 ho effettuato l'aggiornamento è funziona in maniera perfetta, non riscontro questa lentezza nel cambio canale e molto veloce in tutte le operazioni bisogna capire che velocità volete riscontrare e sopratutto avete un parametro di riferimento.????
è un aggiornamento che sicuramente non stravolge ma migliora affidabilità
