Sony WF1000XM4 Battery Drains Too Fast (Left Earbud)
turkishfella34
Entdecker
Hi, I’ve these earbuds for almost a year now and absolutely love them.
Howevere after the latest update the left earbud started draining like crazy! I haven’t changed any settings. Also the right one drains faster than before but compare dto the left one it’s noticeable slower. Please see the screenshots attached. Look at the clock it’s not even 60 min of usage:
22 ANTWORTEN 22
Anonymous
Nicht anwendbar
Hey there,
Did you try to reset and initialize them?
Hope that helps.
turkishfella34
Entdecker
I tries both but the issue still persists 😞
alsalehyaa
Neues Mitglied
I have the same issue.  Battery drains within 45 min
alsalehyaa
Neues Mitglied
HannahEd01
Hi alsalehyaa, it's time to send it for inspection, when did you purchase them? And did you ever try contacting Sony?
nes_20
Entdecker
nes_20
Entdecker
Mine is over a year ago. I’m sure the warranty already expired!!
Piscie
I'd actually recommend resetting & initializing the headphones then test again.
profile.country.US.title
Kl0thnicth
Entdecker
Hi,
I've the same issue, seems to be a common issue with firmware 1.42, other discussion recommends either to downgrade, wait for a new firmware or request a replacement .
Anybody found a solution for it?
