Hi,
Anyone else experiencing registering my new TV. Model KD-49XE7003 as it not listed as an option. Only KD-49XE7002!
Does anyone have an email address for Sony support in the UK
Thanks
Hi
This also happened to me today but I discovered (by accident) if you type the product number, the system presents you with a drop-down selection window with the KD-49XE7003 listed. Copying and pasting does not work even though it thinks it did as it has a tick!!
I have now registered my TV.
David
Hi @DrinkwaterP and welcome to the Community
There have been a couple of members experiencing problems
with product registration recently.
I have escalated this for you, if I hear anythign I will post back here.
Thank you
Hi
David
Philip
I think I might be confused between Product and Model !!
It's the KD-49XE7003 you need to type (not copy and paste)
I hope it works for you
David
