Podziel się wrażeniami!
Hi
The Sony A90K comes with two Remotes - a plastic one and a metal one.
if I purchase an additional remote for each, is there any problem using duplicate remotes?
Thanks
Rozwiązane! Idź do rozwiązania.
@Willie16 wrote:The Sony A90K comes with two Remotes - a plastic one and a metal one.
Hi @Willie16 The plastic one is just an ordinary IR remote, so you can have and use as many as you like. However the metal one is Bluetooth and you can only connect one at a time. Connecting a new one will disconnect the existing one.
Edit: I just turned off Bluetooth to see if the metal one uses IR, it does! So again you can use as many as you like. However, only one can use the assistance button (voice) because it needs to be connected by Bluetooth.
Thanks Lightfoot for your helpful reply. That’s exactly the information I was after.
Thnak you again for the clarification.
Kind Regards
Willie
