KDL-42W705B Media Player - MKV files?
Bluetoot
I have the KDL-42W705B and would like to play MKV video files from a USB drive which I plug into the TV.
The TV can play some video files, but it seems not to be able to play MKV files.
Is there anything I can do to upgrade the media player or fix this issue?
Also, is there a way to display the full filename of the files on the USB stick, rather than the tiny display icons it uses by default?
Many thanks.
1 REPLY 1
Sean_Mc
Hi Bluetoot,
You can find more information on the KDL-42W705B Playable File Formats here.
Hope this helps!
Thanks,
Sean Mc
