- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hello there
My gf has a Sony Bravia. she lives in a block of flats and has her freeview tv connected to the wall by coaxial. A channel was asking for a rescan to work so I did that but can't find any channels.
I did it selecting Cable, it didn't find a thing.
I tried again with Antenna and it ran for hours but the progress bar for scanning didn't move.
This area is best with Crysta Palace; I looked at Manual tuning and it said signal strength was strong for Channel 22 and 23... what am I doing wrong?
Thanks
Saurabh
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi
I think it might be worth 'blanking' the channels in this instance and retuning again.
- Disconnect the aerial cable from the tv
- Do a full retune - this should wipe or 'blank' all the channels.
- Connect the aerial lead back again
- Do a full rescan
Note: Antenna is when you get your Freeview signal via an aerial (The Yanks call it Antenna). Cable is when your get it via Sky or Virgin.
Cheers
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi
- Do a full rescan
Cheers
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
thank you! I'll give that a go tonight... as long as she lets me through the door
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
still wouldn't scan, but your 'blanking' comment resonated so I reset to factory settings and then it found all the channels
Thanks for your help
Saurabh
