Xperia and Quickdial
SOLVED
Not applicable
I recently purchased Xperia Pro, coming from a good'ol Touch Pro 2.
The overall experience with my new device is absolutely great, but, something very simple and convenient is really missing : QuickDial !
I know there's some dialer replacements on the market, but this simple feature is a must have for a labelised "Pro" device destinated to handle many contacts' informations.
Do other users feel the dialer limitated ? Is there any plan @ SE side to properly implement this feature in a future release ?
1 ACCEPTED SOLUTION
slimshaddy
Hero
hopefully ICS update have the quickdial... it will come in january or march..
5 REPLIES 5
slimshaddy
Hero
Not applicable
So the wait will be more intense Winking_Face
gwhispererz
Champion
Hi, not sure if this is what you are looking for.
You can actually create shortcut on your home screen for this purpose.
From home screen, long press and select Shortcuts>Direct dial, choose from contact list.
Not applicable
I meant a quick dial integrated in the dialer's phone pad. So you just use T9 entry to parse contacts quickly.
gwhispererz
Champion
Ok, Quick Dial integrated Dialer .... hopefully we will see it coming soon. Slightly_smiling_Face
By the way, thank you. Slightly_smiling_Face
