I recently purchased Xperia Pro, coming from a good'ol Touch Pro 2.
The overall experience with my new device is absolutely great, but, something very simple and convenient is really missing : QuickDial !
I know there's some dialer replacements on the market, but this simple feature is a must have for a labelised "Pro" device destinated to handle many contacts' informations.
Do other users feel the dialer limitated ? Is there any plan @ SE side to properly implement this feature in a future release ?
hopefully ICS update have the quickdial... it will come in january or march..
So the wait will be more intense
Hi, not sure if this is what you are looking for.
You can actually create shortcut on your home screen for this purpose.
From home screen, long press and select Shortcuts>Direct dial, choose from contact list.
I meant a quick dial integrated in the dialer's phone pad. So you just use T9 entry to parse contacts quickly.
Ok, Quick Dial integrated Dialer .... hopefully we will see it coming soon.
By the way, thank you.
