When i try to open a website i get the message: network not available. Worked previously very well. Is something wrong with the phone?
Could it be something as simple as the phone not being connected? Do you have the 3G or wifi symbol at the top of the screen?
Thanks! Problem is solved. Indeed the 3g symbol wasn't there. The UMTS-send installation was out of order all day. It had nothing to do with my xperia.
Phew! Glad it's now sorted out.
nvm
nvm?
