Hi, how to transfer only a contacts incoming calling to voice mail?. Not for all contacts, only for a one (tipicall spam call i don't want to answer and don't want they disturb me)
first you have to save the number to your phone as any contact,,
in the contact list..select that particular contact..
then select edit..
then scroll down..
and you';ll see the option..
send directly to voicemail
It this the last option in "edit"?. I have a spanish phone, and here is called "Env llams. direc como msj voz". If this mean redirect to voice mail, it is the worst translate I ever seen.
I think this is the option, but I was not sure.
Thanks
yes it means that only..
use translate.google.com
and confirm it 🙂
mark the thread as answered..
thanks
