Google Calendar
RESUELTAS
No aplicable
Google Calendar
Hi,
I did not manage to access directly google calendar from my phone.
I had to go through the browser to see. Isn't there an app for that?
Thanks
1 SOLUCIÓN ACEPTADA
Soluciones aceptadas
suze
Líder
In your Home Screen, if you drag up and select Settings>Data Synchronization and ensure that your calendar and automatic synchronisation boxes are ticked.
I do use a separate calendar app free from the market called Jorte which also syncs with Google Calendar - I just prefer the way it looks. I have the large X10 but its a freebie so you could download it and give a try to see if it works OK on the mini's.
Ver la solución en mensaje original publicado
2 RESPUESTAS 2
suze
Líder
No aplicable
Hi thanks for your answer.
It works well with the default calendar, i will try the other app as well.
