I had Navigation App out of the box, i received a notification for system update i updated it and after that i lost the navigation app.. Now i cannot access the gps without using the internet. How can i get the app back? Please help!
Gelöst! Gehe zu Lösung.
The navigation app is still there, its integrated to Maps, before we had 2 separate icons but Google decided to keep them together, you can make maps offline
But now will i have to update google maps again coz i cannot even open it without mobile data disabled ???
You can uninstall the latest update
Settings > apps > all > maps > uninstall updates
also you can access maps while on wifi and then select a region of a map that you want to make it available offline. Also there are other maps that are available offline
Hello I tried your solution but the icon does not appear I would appreciate it indicates that I do thank you very much,.
Dear friends,
for me also Navigation App uninstalled after update 15.5.A.0.18(4.3) in Xperia M dual. pls help me how to bring back Navigation App
