Clock freeze
Saat
Clock freeze
Your phone freezes, it's left behind, I formatted it back to factory settings, it still does not improve, you will help
21 REPLIES 21
Emil
Enthusiast
Hi @Saat,
I'm sorry to hear this. Could you elaborate what it is that isn't working with your phone? I'm not quite sure I understand your question. Is it the phone that freezes or just the clock app?
If it's the phone I recommend that you try and temporarily remove your SIM and SD card from your device to see if they may be causing this behavior.
If you get back with some more information regarding this,  I'll do my best to assist you.
Saat
Like the photogood, the phone is clocked, the screen clock is running
Lord_viridis
Try booting in safe mode
Do you see the same issue?
Saat
I open it in safe mode, how do I do a preload
Lord_viridis
A preload?
Saat
How to preload
Saat
how to boot in safe mode?
profile.country.US.title
Qatrium
@Saat
Use the blue link for a guide, it was also there on @Viridis's reply
safe mode
Saat
thank you
