Your phone freezes, it's left behind, I formatted it back to factory settings, it still does not improve, you will help
Hi @Saat,
I'm sorry to hear this. Could you elaborate what it is that isn't working with your phone? I'm not quite sure I understand your question. Is it the phone that freezes or just the clock app?
If it's the phone I recommend that you try and temporarily remove your SIM and SD card from your device to see if they may be causing this behavior.
If you get back with some more information regarding this, I'll do my best to assist you.
Like the photogood, the phone is clocked, the screen clock is running
I open it in safe mode, how do I do a preload
A preload?
How to preload
how to boot in safe mode?
thank you
