album goes black
SOLVED
ahmdsaalim
album goes black
Hi I'm using xperia L, I'm facing issue that I can't see the images in the album. After opening the album application it goes black it doesn't showing any picture.if I touch there the picture is opening I can see the notification light is blinking but the screen is black. If I go for the option like edit I can crop the image at that time I'm able to see the image.please help me to sort this out...
1 ACCEPTED SOLUTION
Alexander1
Champion
Hi,
I suggest that you clear data for "Album" and "Media storage". Go to settings > apps > the tab "all" > album > clear data. Do the same with media storage.
Restart your phone and wait for the pictures to load in album again. It can take some time after you have cleared data for the media storage.
What are your thoughts about this forum? Let us know by doing this short survey.
16 REPLIES 16
Alexander1
Champion
Hi,
nik007
thnxx man...it works!!
sunandmahajan
thanks a lot bro ............ i had been facing this problem from a long time ........ and finally got it solved ....... thanks a lot   Slightly_smiling_Face Smiling_Face_with_Sunglasses
ahmdsaalim
Thank you alexander its working fine...This problem came after using cache cleaner, now im using memory cleaner app.its working good:smileyhappy::smileyhappy:..
Aniket_007
Thnxx a lot dude.....Ur formula Worked....
Miroslav
I had the same problem on Xperia Go now the problem is solved. Thanks a lot dude
sebastiankreuz
@Alexander wrote:
Hi,
Hey Alexander I was looking to fix this problem everywhere and I tried your solution since not only you suggested it, but the phone completely erased all my pictures, videos, music... all my media files, gone...
Now I'd like to know if there's a way to recover that, I'm really pissed off now.
Sebastian.
profile.country.RO.title
_alexdon_
just restart,it will be fine.
alexdon
sebastiankreuz
Mate, I've restarted already. I've even plugged in my phone to a PC to check the files in it and everything's gone.
