SVR-HDT500 and IPlayer
SOLVED
dacallo74
I've just bought a SVR-HDT500 and set it up. I thought that I had read that it would play IPlayer, so I connected it through an ethernet cable to the hub. Have no idea what to do next. I have read the manual and cannot find any reference to it. Was I dreaming or can it connect to the internet?
Tags (1)
1 ACCEPTED SOLUTION
Anonymous
Not applicable
Hi there
If you have set it up correctly,  All you have to do, it go on a BBC channel (ie, BBC1) and press the red button.  You will see iPlayer in the menu there.
5 REPLIES 5
Anonymous
Not applicable
Hi there
dacallo74
Thank you. That works.
hxd560
hi
when i do as suggested and press the red button only teletext comes on the screen not iplayer is there something else i could be doing wrong
heidi
Anonymous
Not applicable
Have you connected an ethernet cable from your router to the SVR-HDT500?
hxd560
hi thanks for your reply i have connected the modem by cable to the player heidi
